Throttle body
2 reading
99 views 8 replies 3 participants last post by  Kaiju
#1 ·
Everything you’ve ever wanted to know about the throttle body, but were afraid to ask.
I came up with a p0121 and p0123. When I hooked up the scanner, I had full voltage of 4.8v on the VTA1 output of the throttle body. When I would start the car, the rpm would shoot up to about 2000rpm, the CEL would immediately kick on, and the idle would go all the way down to about 500rpm before settling back to 700rpm. If I stepped on the gas, I could get about 2000rpm. Limp mode.
I hooked up the scanner to my 2007 and got a set of good numbers.
When I stepped on the accelerator pedal, I could see the “accel sens #1 and #2” change the same on both vehicles. I’m pretty sure I’ve gotten this isolated down to the throttle body, so I ordered a new one.
I’m pretty sure I’ve got a short inside the circuit on the throttle body #1 or “A” circuit.
I went ahead and took apart the suspected failed throttle body. Here’s what I found:
Inside the riveted housing is a motor that is water cooled, a reduction gear, and the butterfly valve attached to a Hall effect sensor. The circuitry is inside the black plastic housing.
By my inspection, the motor, reduction gear and butterfly assembly all appear very robust and in good condition. Aside from a failed motor, I see little that can fail in the hardware.
What I suspect happened in mine is a failed capacitor contained inside the sealed black part. This led to a short condition where the 5v reference signal was allowed to pass thru without being “modified” by the Hall effect sensor.
New hitachi throttle body is on the way and should be in today. Will update the forum once parts are installed.
2013 Toyota FJC x 2 Base owns
2007 is AT. 2013 is MT and dual VVT
#2 ·
Interesting. The TB on the 2013 failed before the one on your older 2007. So you believe you got a short in a capacitor within the control circuitry, allowing an unmodified voltage signal to pass through? Makes one wonder. So if it is a capacitor faliure, did a high voltage transient at one time cause a dielectric breakdown within one of those tiny control circuit capacitors or was it a slow fail due to a manufacturing defect? Failures in TBs are relatively rare, fortunately. How many miles on the 2013?
#6 ·
Capacitors do fail. Over voltage is the usual failure mode as current blows through the dielectric material and causes a short, but manufacturing defects can also occur. There's really no way to test those unless one can get the circuit board out of the housing and separate the components to individually test them. I also doubt the Hall effect part of the system failed unless there was mechanical damage to the housing.
#7 · (Edited)
Agree on the hall effector not being a failure point. There are really no moving parts of it to fail, other than the butterfly flap becoming separated from the plastic gear, but that looks very unlikely, and would be very easy to detect.
Here’s how the hall effector works:
In the housing is a fixed magnet. That’s the horizontal dark line. This magnet creates a field which is sensed by the magnets on the rotating butterfly flap, thus creating a system that can make a usable signal for the ECU to interpret.
This field interacts with other magnets that are fixed on the rotating butterfly flap. As it rotates, these magnets act as a potentiometer, which changes the 5 volt reference voltage being routed back to the ECU. The ECU interprets the varying voltage as throttle angle. When the flap is closed, the ECU knows it should see about 0.8v. When the throttle is wide open, it should see about 4.5v. In my case, I see 4.8v coming back to the ECU from the reference voltage, which can only be a short in the internals of the throttle body.
Now that I think about it, when I first brought this FJ home back in August, I couldn’t get it up the driveway because it was in limp mode. I had to put the differential in 4L to get it up my slightly inclined driveway. I had 16 CELs when I brought her home. I attributed that to the suspected bad head gasket. Now I’m thinking it was this.
In the schematic is where I think I have a problem.
UPS hosed me, my part is now delayed until Monday, and I leave Sunday night for work. Will have an update next week….
Hope unpacking the internals of the throttle body helps someone someday!
